How can you capture sound from a Pinnacle DC-10 capture card, I understand you have to have a sound card which all computer does, my had one on board, my old Canon 8mm analog camcorder has an RED and WHITE RCA plugs for audio and my sound card line in had a different kind of mating hole(s) Is that mean I have to go Radio Shack to get an adapter for that? THANKS.
Most sound cards use a 1/8" mini connection. You can get a Y-adapter, which is available at most electronics stores. The Y-adapter would have a 1/8" mini male connection on one end and 2 RCA male connections on the other.
I think there are also Y-adapters with female RCA conenctions available. Of course, if you get the one with the male ends and you want to connect an RCA cable to it, you can get a pair of couplers which will allow you to connect the 2 male ends together.
Capture Card With No Delay Input Capable of 720p+ @ 60fps?
By NeoCyrus in forum Capturing and VCRReplies: 34Last Post: 3rd Feb 2011, 23:32 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card with HD input?
By DiabloTerrorGF in forum Capturing and VCRReplies: 19Last Post: 3rd Jul 2009, 14:18 -
Trying to find Capture Card - w/ Component input
By tS_veXed in forum Capturing and VCRReplies: 63Last Post: 21st Nov 2008, 07:08 -
Capture card with Component (RGB) Input and 16:9 Support
By edt in forum Capturing and VCRReplies: 21Last Post: 27th Jun 2007, 09:58
