Hi All,
I have been using DVDDecrypter & Instantcopy for some months now with no problem at all. Tonight I loaded up DVDDecrypter and got an update notification that there was an update. I updated and all went well. After the update I loaded DVDDecrypter up, popped in Matrix Reloaded and chose to back-up the main movie only. I then loaded InstantCopy only to find that when I browsed to the folder where the disc had been ripped to, there was nothing there (not the normal VIDEO_TS file) I changed the view to 'All Files' and found all the bups and ifo's. DVDDecrypter seems to have done it's job but not in the same way that I am use to. The only thing that I have done different is chosen to back-up the main movie as oppsed to the whole disc.
Is this normal and do I now have to use something different to InstantCopy when I rip the main movie only?
Many Thanks For Your Time
As far as I know you always have to rip all the files when using InstantCopy. IC8 has a movie only mode...but it still requires all files to be ripped.
Thanks for the reply,
After reading some other posts I decided that it wasn't worth just ripping the main movie so, I did the whole disc.
Put the finished disc in my set-top player and it freezes every 5 seconds. I can then hit fast forward at it plays again or hit next chapter and it plays again but then freezes 5 seconds later. Any ideas anyone please?
Many Thanks
DVDDecrypter not ripping vobs correctly
By vcd4me in forum DVD RippingReplies: 4Last Post: 16th Jan 2012, 17:08 -
DVDDecrypter error reading disc
By walker08 in forum DVD RippingReplies: 11Last Post: 7th Apr 2009, 00:54 -
DVDdecrypter region code not set. Help
By X_Splinter in forum Software PlayingReplies: 2Last Post: 9th Sep 2008, 18:08 -
Imgburn Vs DVdDecrypter
By avextraxjp in forum Newbie / General discussionsReplies: 11Last Post: 9th May 2008, 09:17
