I converted the component video files over to mjpeg encoded quicktime movies. What I wanted to do was compress these down to an XviD avi. Well, I chose "DivX 3 [.AVI] (ffmpeg)" first, because I thought, ok so I know my other computer can play DivX better than XvidD anyway, and I don't care as long as its smaller and playable on other computers. It took about 4 minutes of the candy cane status bar to ding, and the result was a 0k, totally useless avi file. I had the same result with an mp4 encoded quicktime file, only it took 2 seconds to ding and create an empty avi file.
I decided to try mencoder, and picked "XviD [.AVI] (mencoder)" It took a while, but it finally encoded 2.5 minutes worth of video to a hefty 24.4M file. Not very good.
I'm having nothing but bad luck here...
Guest
Select DivX (libavc) quick preset, and email me the process output to major4@mac.com in case of problems.
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 07:31 -
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
