I am wanting to put all of my home movies currently on DV tapes onto DVDs so i have a permanent copy of them, but also be able to use those DVD clips as source clips for future projects. I dont need to play the DVDs on a stand alone player, I just dont have enough room on my hard disks to store AVIs at 12 GB/ hr?
Can MPEG2 be edited in Premiere etc? I just need a solution that will allow 1 - 2 hrs of clips per DVD.
cheers.
Capture the DV from your tapes as DV AVI. Then go to the Convert and Capture sections to find a suitable way for you change the captured DV to DVD MPEG and subsequently burn them to DVD. To find a permanent way to store DV other than your tapes is not economically available just yet. Hopefully the DVD 8 disks will be an answer.
Hello. -
Mpeg-2 can be edited, though I don't think premier will do it. Doing anything more than simple cuts and joins is very problematic. Mpeg-2 was never designed to be an editable format.
Why not just keep the original DV tapes, they aren't that expensive are they?
Edit. If you really want to find a way to edit mpeg-2 take a look at this thread.
Can't edit video file converted from DVD to AVI in Adobe Premier
By GalMed in forum EditingReplies: 12Last Post: 24th Feb 2012, 13:53 -
How do i get 11gb of avi file onto dvd for backup purposes without dual lay
By wolf422 in forum EditingReplies: 2Last Post: 29th Oct 2010, 21:09 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13 -
DVD to AVI (no divx!) to edit in Pinnacle software?
By erol in forum DVD RippingReplies: 1Last Post: 7th Sep 2007, 03:33 -
DVD to AVI files to edit in Premiere 6.5
By nuts4dv in forum DVD RippingReplies: 2Last Post: 7th May 2007, 01:16
