Okay, heres my situation. I ripped with DVD Decryptor but only ripped the default files that it selected (I didn't to a ctrl-A) and I want to strip out some of the audio tracks and subtitles and burn it to a DVD-R to play in my DVD player. I tried Using DVD2One how ever every movies I've processed through DVD2One will freeze at certain spots during the movie when played back on my Pioneer DV-C36 DVD Player. So I need to process the files with something other then DVD2One. I've tried DVD Shrink and it keeps saying "DVDShrink has encountered and error and cannot continue this operation, file doesn't exist" I'm assuming I'm getting this message because I didn't rip the entire DVD content to my hdd. I've also tried DVDFab and after I select the files and click continue it say its analyzing DVD for about half a second then the program quits.
So my question is how can I process the dvd files so i can strip out the unwanted audio tracks and subtitles and fit it on to a dvd-r without using DVD2One? I know the easist answer is to re rip it with DVD Decryptor and select all the files but there has to be a way to do with with what I've already ripped, no?
Since you are having so many problems with what you have ripped, why can't you re-rip if it is the easiest way?
Hello. -
Try ripping it again using Dvdshrink V2.3 beta 5. I understand u want movie with subs only, dvdshrink will do it, but it might only do it from the orginal dvd....SasArchiver (its has options to select subtitles, languanges etc, and makes the dvd smaller at the same time)
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights -
Why is that so important ? It would be far easier to just rip it again.there has to be a way to do with with what I've already ripped, no?
Is there a problem with that ?
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
