Hello, my camcorder doesnt allow me to download to my PC. I want to be able to transfer to VHS and then to VCD. I have a wintv capture card. What software is available for me to achieve this? Cheers
We were put on this earth to do good to others, what they do I don't know
Your camcorder should capture to mpeg-1, then you should convert to mpeg-1 VCD format. If you have Ulead Video Studio, it can capture in mpeg-1 VCD (trial ware). You should not transfer to VHS, then to VCD, you are taking an unnecessary step. If you cannot capture in mpeg, then capture in AVI with Virtual Dub, then use TMPGEnc with its templates to convert to VCD mpeg.
Hello. -
Ill check my camcorder to see if it will convert to mpeg. Thanks m8 for the help. cheers
We were put on this earth to do good to others, what they do I don't know -
Sorry, I need to clarify. Your computer hardware should try to capture your camcorder video to MPEG. Your camcorder probably does not output MPEG video. So when you are capturing, see if you can find a program that can capture your camcorder video into MPEG format. Sorry.
Hello.
vhs cassette not sitting down one side in vhs recorder ?
By oldfellow in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2012, 16:23 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
