  1. how do i rip and burn a multisession dvd ? i have tryed twice and failed,
    all help wld be great
    cheers guys
  2. I think maybe you have got the terminology a little wrong here.
    A multisession dvdr/rw is one that you create, using burning software and is not a DVD. You wouldn't need to rip one of these.
    Explain in a bit more detail what you are trying to do.
    Do you mean a multi episode DVD ?
  3. ok i riped a dvd and when i went to burn it nero sayed this disc is a multisession disc and may not work on some os systems prior to windows xp . so i tryed burning it anyway but it stoped half way and gave me a error . so i then tryed burning it with copytodvd it did not like it either and hardly even started burning it before it stoped , so is there a special way i need to rip it ? (used dvd decrypter) or burn it ?
    cheers guys
