Hi
I used a Pinnacle PCTV Plus card to capture my Hi8 video tape to MPEG1 VCD format using Ulead Videostudio 7.After capturing the file had no A/V sync problems.But then i edited, inserted transitions,titls,etc using Videostudio.After encodeing the edited video into another MPEG1 VCD file i got A/V sync problems-there was around a 2 second difference between the audio and video.I also tested it on standalone VCD players with the same problem.Why is this so?How do i correct this?
That is probably the most frequently asked questions here. :c)
So, you are not alone. If you do a search right on this page for "audio video sync" you will find lots of possible casues and solutions.
Probably more than a day's worth of reading.
Welcome & good luck. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
i'm still not able to get the relevant thread in the forums.Can someone please help me out?
Audio out of sync after editing in MPEG Streamclip
By Rhymester in forum EditingReplies: 0Last Post: 7th Nov 2011, 05:03 -
[Audio] Capturing, editing, keeping a/v in sync and dynamic resampling
By rmdeboer82 in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2011, 14:16 -
Audio sync while editing in Pinnacle
By p_uriel in forum EditingReplies: 5Last Post: 13th Jan 2011, 14:13 -
Avidemux editing causing audio sync issue
By perdomot in forum EditingReplies: 0Last Post: 14th Sep 2009, 15:29 -
Audio/Video Out of Sync/Lag When Editing Clips
By DrawnIntoIt88 in forum EditingReplies: 2Last Post: 15th Dec 2007, 08:03
