Need some help with changing from LP to SLP, so that I can make a DVD5 biger. If this is posible???
I need more space on it, an I so on the back of the DVD+R several diferent setings or recording modes. All the way from 60 min. to 360 min.
You increase the amnount the DVD can hold buy adjusting the bit rate. Try this guide. It was for CDs, but the same principle applies to DVDs.
Hello. -
those ratings on the package are intended for stand-alone recorders which adjust the bitrates automatically depending on what speed you select. just make its more user friendly for people more use to a VCR. On a PC you adjust the bitrate itself.
Best not to look for "posts" A good place to start is What is DVD - top left corner and proceed from there.
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
:c)
If you are actually looking for a bit rate calculator, those are listed in TOOLS section: https://www.videohelp.com/tools#VideoBitrateCalculators
But the first section I recommended shows the proper bitrate ranges for DVD.
Hope that helps. :c)There's no place like 127.0.0.1
Audio track speeds up going from AVI to DVD
By jenna1 in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2011, 15:22 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 07:28 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 05:49 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 04:32
