Using reauthorist encoding with cce and my reauthored size is 4064.14MB but when I remux everything in scenarist I get a place holder for the vob file so I change it to data but the dvd size then increases to 5176MB so its to big to fit onto dvdr
Is it just being reported incorrectly in reauthorist or scenarist ?
whats causing the problem ?
any ideas
VTS_07_0.VOB
This is the menu but for some reason its not being included when I encode with cce so when this is added when I remux it takes the size over
any ideas ? -
above is from forum rules stated above each post you make.Please try not to bump your topic(reply to your own topic) immediately, wait at least a few days.
You haven't waited very long. Identifying the vob is not going to help anyone help you. :c)
I suspect very few here use that combo of programs. It may be a wait to hear back.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
what do you mean you "change it to data"??Originally Posted by jayosw
I use Scenarist all the time and you DO NOT include the menu VOB during the encode process....that is why it isn't being included. Once the scenarist project is finished you replace the original VOB files with the authored VOB files and then use ifoupdate.
you can find more helpful information over at doom9.org
Req: Configuration help for best audio/video using freeware and PC
By Morcas in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2009, 07:47 -
Req. .rv to .wmv converter or .rv player
By naufil in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2009, 04:20 -
Req: Software For A Faster Pc Start
By Teac23 in forum ComputerReplies: 8Last Post: 14th Jan 2009, 09:46 -
REQ : - SOUND Distorted from footage
By mojoeuk in forum EditingReplies: 2Last Post: 23rd Nov 2007, 14:54 -
Mac Mini - Leopard Memory Req?
By edDV in forum MacReplies: 9Last Post: 3rd Nov 2007, 12:16
