hi,
I'm using Power VCR II to capture television shows and VHS tapes. I am using ATI TV wonder VE and I know you can only use Mpeg 1 or mpeg 2 to capture stuff using power vcr but I know you can edit the properties of mpeg 1 and 2. My question is, how can i have watchable quality and take up less hard drive space. I have set it up using MPEG 1 excellent and 30 minutes of video takes up 600 to 700 megs.
May I ask a simply question. What do you intend to do with these files after capture. Author to VCD or DVD? This is important in deciding what your capture settings should be. While I used Power VCR II early on, there are much better programs that give you more control over your captures.
I was going to store them on my hard drive. I can't use the divx codec because whenever I play divx files on my computer, it will restart it self. Difx files don't like my ATI Radeon 9000 pro.
Well then I hope you have a lot of room and someday plan to get them on disk.
Why not use ATI MMC that came with the card and use it. It can capture numerous formats. Guides at my site.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Power adapters for external capture cards
By pinetop in forum Capturing and VCRReplies: 0Last Post: 5th Mar 2011, 00:34 -
capture from vcr
By bbxrider in forum Capturing and VCRReplies: 27Last Post: 16th Aug 2009, 16:18 -
VCR capture troubleshoot
By Abas-Avara in forum Capturing and VCRReplies: 11Last Post: 16th Aug 2009, 04:26 -
capture video from VCR
By nbdeb59 in forum Capturing and VCRReplies: 2Last Post: 2nd Jul 2009, 23:57
