  1. How can I tell if a DVD is a DVD5 or DVD9? Can regular DVD writers burn onto DVD9s? Can you buy DVD9s or are they just for commercial use?
  2. How can I tell if a DVD is a DVD5 or DVD9?
    On the back of most DVD packaging (near the Dolby Digital logo) it should say whether or not it is dual layer or single layer.
    No, to 'write' to DVD9's you need to use a commercial press. I believe that technology is in the works to create recordable DVD9's.
    As per above, just for commercial use really.
