I came across this site about software to copy dvd's. Has anyone seen this before? Or is it fake?
http://www.dvdcopy.tv/
Here's the faq
1.
Q : Is DVD-COPY 2.1 compatible with Windows ME?
A : DVD-COPY 2.1 is compatible with Windows 95/98/ME/NT and 2000. DVD-COPY will NOT run on Windows 3.1 and hasn't been tested on Windows XP yet.
2.
Q : Is DVD-COPY 2.1 compatible with Macintosh?
A : DVD-COPY 2.1 is Not compatible with Macintosh systems at this time. Check back with us in the future.
3.
Q : What is the minimum hardware and software requirements for using DVD-COPY 2.1?
A : At a minimum, you will need the following items in addition to DVD-COPY 2.1:
1. A DVD-ROM Player installed in a computer
2. A CDR (CD Recordable) installed in a computer (need not be in the same computer)
3. Blank CD-R's (for recording)
4. You need to be running Windows 95/98/ME/NT or 2000
4.
Q : Can DVD-COPIES be played on a standard DVD Player?
A : Most DVD-COPIES can be played on a standard DVD Player, provided the DVD Player supports Video CD (VCD). Most DVD Players manufactured within the last two years, support the standard Video CD format. Refer to your DVD Player owners manual for more information or click here to check on the VCD compatibility of your DVD Player.
5.
Q : How many CD-R's are required to burn one DVD?
A : That depends upon the length of the DVD video, and whether or not you plan to play the CD in a conventional DVD Player using Video CD technology. If you want to store the movie in a compressed MPEG or DIVX format and replay the movie on your computer, or computer to the TV, then one CD can be sufficient with specific compression technologies. But if you want to store the format in VCD and play it on your console DVD player, then two CD's will typically be required to hold a full feature length DVD (2 - 2 1/2 hours). You can store (depending on the CD-R) up to 80 minutes of video on one CD-R in VCD format.
6.
Q : Will my CD retain the same quality and digital stereo that is on my DVD?
A : Actually, VCD quality is much better than VHS, but not quite as good as DVD. Some can tell the difference, while others can't. The audio portion is recorded in true digital stereo and you will retain the same aspect ratio of a DVD. Many of our customers maintain a library of DVD Videos on their computer hard drives as well. This allows them to make an exact copy of the original DVD, video, audio and all MENUS! So there is no difference between a DVD VOB file on your hard drive and the VOB file on a DVD. They are IDENTICAL in every way!
7.
Q : Does the copy retain all of the bonus footage and menus?
A : That depends on whether you store the DVD to your hard drive or you store it to VCD or DivX format. If you store the DVD to your hard drive, you can retain all bonus footage and menus. However, neither VCD or DivX can retain the bonus footage or menus. You can, however, use our software to copy specific footage from a DVD, like movie trailers or interviews.
8.
Q : What is VCD?
A : VCD stands for "Video Compact Disc". Basically, it's a CD that can hold 650 or 700mb of audio and video data. In short, this means it is similar to a DVD, in that it is digital and can contain video data. Even though a VCD's audio and video quality are not as good as a DVD, most people cannot tell the difference between a VHS and a VCD movie. Anyone else who does know the difference will say VCD is better than VHS. VCD can also be played on most console DVD players connected to your television.
9.
Q : What is DivX?
A : DivX is a codename for the MPEG-4 compression technology developed by DivXNetworks, Inc. (aka Project Mayo). DivX is similar to VCD in it's video quality, but almost anyone will tell you it's not as good. This is basically because of the difference in resolution. All televisions display on a 640x480 resolution. Computer monitors are typically set to 800x600 and 1024x768. DivX cannot be played on standalone console DVD players. This is one of the strongest points against it. Most people prefer the option of sitting on their couch and watching movies on their television, as opposed to their computer screen. DivX is ideal for those who travel, or prefer the direct availability of DivX movies over the internet.
10.
Q : Will DVD-COPY 2.1 work with all CDR burners, for instance HP 8200 and HP 9100 Series?
A : DVD-COPY 2.1 has been tested with most major CDR products and has been found to be compatible with all of them.
11.
Q : Is the DVD-COPY Process complicated?
A : Although the DVD-COPY process can appear complicated at first, you will discover that we've made the process as simple as possible and provide step by step instructions from beginning to end.
12.
Q : Do I need to buy a DVD-Burner?
A : NO! You do not need an expensive DVD-Burner for use with DVD-COPY. If you have a DVD-Burner, do not purchase DVD-COPY. You already have everything you need to burn and copy DVD Video.
13.
Q : Can I copy my VHS tapes using DVD-COPY?
A : Our software doesn't support copying VHS tapes at this time. In order to achieve this you will need a video card with a Video In port for a camcorder or VCR and the software necessary to capture the video.
14.
Q : Why can't I download the software rather than having it shipped to me?
A : The DVD-COPY 2.1 product is just simply too big. The download size is not practical for most people with a dial-up connection. You will also benefit from the CD which will provide a master backup of the DVD-COPY application, should you ever need to reinstall.
15.
Q : How do I know DVD-COPY will work for me?
A : That's why we offer a full, 90 day, unconditional money back guarantee. Although the DVD-COPY 2.1 software product has proven itself time and time again, there are rare exceptions when our customers cannot make the product function, for reasons related to their particular hardware and software configurations. It doesn't happen very often, but in any case, we are always more than happy to honor our agreement and refund your full purchase price if you are dissatisfied with the DVD-COPY product for any reason.
16.
Q : How can you make such an offer on your guarantee?
A : Due to the large volume of consumer purchases, we can keep the price low and provide a rock solid guarantee. We already know that the majority of our customers appreciate the value of the DVDCOPY product line and also appreciate the email support, product enhancements and upgrades available only to registered users of the product.
17.
Q : I don't want to purchase over the Internet. Can I purchase by telephone instead?
A : Absolutely! You can call 888-656-0646 in the US and talk to a live operator. Please remember if you have any questions about the product or need technical support, email us at support@321studio.com. The phone operators cannot answer your questions that are not already answered in this FAQ.
18.
Q : Can I download a demo of the software?
A : Presently, we don't offer a demo for download. We are however working on one at this time and have plans to release a demo before the end of the year.
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
.cdr on a DVD+ needs to be converted
By jamesmarcustucker in forum Video ConversionReplies: 20Last Post: 8th Sep 2007, 15:40 -
CDR TO DVD software please
By Lennoxtown in forum Authoring (VCD/SVCD)Replies: 5Last Post: 7th Aug 2007, 12:04 -
DVD Media... NO CDR!
By Lighters in forum MediaReplies: 5Last Post: 5th Jun 2007, 11:26
