Hi
I have just downloaded a DivX movie, and when I try to convert it to MPEG1 with TMPGenc it says that there are some bad frames, and I mean more than 100 or something, what can I do?
I have tried the same thing with another movie, but with only 4 bad frames, then I encoded up to the first bad frame and then after the frame up to the next bad frame and so on. I ended up with 4 files in all, but they were all filled with green blocks, and the movie was impossible to see. HELP ME!!!
Just try VDub, it can decode almost everything and then do the frameserving stuff, may take a bit longer but should work !!!
GIMP GAP Green Frames
By mixt in forum Newbie / General discussionsReplies: 9Last Post: 25th Apr 2011, 09:45 -
Getting frames from a broken 3gp
By tussu in forum Newbie / General discussionsReplies: 5Last Post: 6th May 2009, 19:32 -
Captured AVI frames broken/split/badly aligned
By cyclometric in forum Video ConversionReplies: 3Last Post: 25th Sep 2008, 08:50 -
How to repair broken frames in MPEG/DVD videos
By misterbean in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2008, 00:02 -
Remove green color from 49 frames
By mlong30 in forum EditingReplies: 5Last Post: 11th May 2007, 00:54
