I currently use a Celeron 400 with Matrox G400 Marvel with hardare MJPEG codec which I use for video capture.
I'm about to change to an AMD T'Bird (1Ghz)with Gigabyte GA-ZX7R mobo system. Would I be better off changing my capture method to s/ware (eg PicVideo or whatever)?
Will the CPU be fast enough for full frame capture, or is the G400 (regarded as one of the better hardware codecs) gonna be good enough?
Appreciate your comments.
Nezza
As a fellow G400 Marvel owner, I'd say stick with the hardware assisted capture. ( Unless you're using Win2k or XP in which case you'll have to use a software codec as the hardware MJPEG of the Marvel is not supported.
If you have lots of disk space, you might want to try a non lossy capture codec like Huffyuv. If you're like me and only have around 15 gig to play with, again stick to MJPEG. ( Either hardware assisted using the Marvel or Picvideo. )
Good Luck
Ian -
It's possible that the G400 Marvel uses a Zoran chipset that can only work with hardware MJPEG encoded video. If this is the case, then you won't get any higher any quality by using an external codec. Huffyuv would look identical but have a much higher file size, and most other codecs would cause a decrease in quality.
-Cart
http://www.geocities.com/lukesvideo/index.html -
Hello,
Just in case no one knows this, the Marvel G400-TV has a hidden YUY2 ability. If you go to http://www.matroxusers.com/Utils.html, look for the Flying Dutchmans YUY2 patch. Make sure that you read the readme file. If you have any questions about this patch, the author (and many users) of it hang out in the Desktop Video forum (http://forums.matroxusers.com).
I've used this with some fairly good results. The captured files using Huffyuv or PIC MJPEG (Q=20) can get higher bitrates than the Matrox MJPEG codec. The difference is noticeable in creating VCDs/SVCDs (much cleaner looking). As with other YUY2 captures, you need a good machine to capture full-frame.
If you are primarily dumping to tape, it does not make much sense to not use the hardware assist. The Zoran gives a very nice color boost.
Before trying any hacks, like the Flying Dutchman patch, check to see if uncompressed video modes already work (like RGB and YUY2).
Matrox's drivers have been supporting these modes for quite some time without any hack.
What Hardware/Software do I need?
By Frank W in forum Newbie / General discussionsReplies: 7Last Post: 3rd Apr 2012, 17:30 -
Hardware Mpeg-2 or Software ?
By video80 in forum Capturing and VCRReplies: 24Last Post: 7th Mar 2012, 20:25 -
Hardware vs Software Encoding
By gabs247 in forum Capturing and VCRReplies: 49Last Post: 28th Mar 2010, 19:31 -
Do you register your software/hardware?
By yoda313 in forum PollsReplies: 6Last Post: 17th Sep 2008, 09:53 -
Hardware Acceleration and codec help
By mx5 in forum Software PlayingReplies: 11Last Post: 1st Sep 2008, 22:09
