  1. Hi
    trying to backup godfather trilogy. Parts 1 and 3 are fine, it is 2 that is causing me grief.
    Basically movie is on to discs. The second disc I can copy without compressing using dvd shrink, no problems. However the first disc (first half of movie), I can not copy on to one disc unless compress by 40% (to much). Only option if I don't want to compress is to use DVD FAB and put on 2 discs.
    Therefore movie will be on 3 discs! This is stupid, how can I back it up on two discs?
    Please help?
    Cheers
  2. 8) this makes no sense
    The electronic components of the power part adopted a lot of Rubycons.
  3. Member holistic's Avatar
    May 2001
    here & there
    Sadly you know the answer but just cannot face the stark truth.
    LOWER THE BITRATE
    There is no magic - a DVD is a specific size (4.38Gb)
    You know your run time (movie length)
    Size - (Audio x Length )) / Length = Video bitrate
    https://www.videohelp.com/calc.htm
  4. Picky!
    You not what I mean, rip it to hard drive with dvd shrink and burn with nero (did not been with dvd shrink)!
