I have the latestest version and del-*****'s guide. The guide is excellent but may be a bit out of date.
He suggests a rate control mode of 2-pass VBR. The new version describes this as an old method and defaults to Constant Quality (CQ). Any help here? Is this the best for almost DVD quality? Any suggestions in the settings for this mode? Since 135 minutes is the DVD standard I use this for comparison. I was able to encode this equivalent in 1.73 GB with Quality=50, max=3000, min=1200.
The only problem was the horizontal line effect. From what I have read this is due to the wrong frame setting. I am using a renedered DV from ULead that says it is frame A first so I set TMPGEnc the same but have a bad horizontal line problem. Is it only frame order that can cause this or are there other factors?
Thank you.
Ulead software shows the opposite frame order of other programs.I am using a renedered DV from ULead that says it is frame A first so I set TMPGEnc the same but have a bad horizontal line problem. Is it only frame order that can cause this or are there other factors?
There was a thread about it just yesterday. I'll plunk in a link if I see it again.
- here it is: https://www.videohelp.com/forum/viewtopic.php?t=183134&highlight=
If you set your field order right, horizontal lines that are interlacing are supposed to be kept in - for viewing on TV or PC with PowerDVD or WinDVD. If you've got it right, they should not show up in either.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
Dark Horizontal Lines
By daave in forum Capturing and VCRReplies: 4Last Post: 14th Aug 2012, 15:26 -
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 10:02 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 10:23 -
Betamax - horizontal black lines near white (example within) & other Qs
By PLC401 in forum RestorationReplies: 37Last Post: 25th Feb 2008, 16:09 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 12:06
