  1. When i opened my dvd decrypter this morning i had the following message:
    "Logical unit region has not been set. This can cause errors when trying to decrypt a disc. Would you like to set the region now? "
    What do i do???
    Please help.
    Same thing happens when i open POWER DVD.
  2. Member holistic's Avatar
    May 2001
    here & there
    Answer "Yes" and select the region that your purchased DVDs are usually from. This will permit your burner and DVDDecrypter (as well as all other DVD-related software) to behave properly...
    source : setarip @ forum.digital-digest.com
  3. Click yes... you need to choose a region for your dvd-rom... If you don't know what region to set it to look here: http://www.pioneeraus.com.au/multimedia/dvd/dvd_region_map.htm
    10110101100111012011 <- The bug Bill doesn't talk about.
  4. Thank you so much for your answers. I really appreciate it since i taught at first this was a very silly question .
    If i say "yes" , will it count as one of my 5 region changes ?
    If so, what caused this?? Cause when i installed my burner last month it was set to region 1. What did i do wrong to make it change my region?
  5. Member holistic's Avatar
    May 2001
    here & there
    I have no answer for WHY it changed.
    Why worry . You are making your own DVD's just make them 'region free'.
