Hi,all!
I have in HD some DVD-movie which contain 2audio streams:
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VIDEO_TS.VOB
VTS_01_0.IFO
VTS_02_0.BUP
VTS_02_0.IFO
VTS_01_0.VOB ---> VTS_01_4.VOB
I have separately prepare 3 (third) audio stream which also in ac3-format.
I only want to put there one more audio stream, what soft will do this
job?
Skeeper
Strip the video and audio with vobedit, you will get a m2v and some ac3 files.
Reauthor the video and audio streams with ifoedit and add your third audio stream.
Fix it with ifoedit.
You can find detailed guides/faqs over at http://forum.doom9.org in the ifoedit forum. -
Thanks!
I have to day also done so like you told, work fine, but problem is that after authoring in Ifoedit I dont seen any Menu on DVD.
Question is now, how can I put this new generated VOBs files into first DVD structure files in order that all original menu will funktion?
Unfortunately I dont found any FAQ directly about that nowhere, also no in http://forum.doom9.org
Skeeper
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 22:40 -
Question about audio conversion to put VCDs on DVD
By jimdagys in forum Video ConversionReplies: 5Last Post: 28th Sep 2008, 22:07 -
Want to put WAV. Audio on DVD. Why not?
By happydog500 in forum AudioReplies: 33Last Post: 21st Jul 2008, 20:48 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
