Okay, from what I can tell from this site... chapters on a VCD are time locations of a single MPG file that you can go to that specified time by going to that chapter. When recording shows with commercials... should I split the MPG videos into seperate mpg files according to where the commericals are, or should I rejoin those pieces and just make a chapter for the VCD? Is there differences between them, either one easier to use? Is it worth the extra work of joining the MPGs and then creating a chapter for each one, or just leave them as individual files when going into the VCD player?
Joining the mpgs takes like 5 mins and authoring the chapters takes maybe 1 min. So the amount of work involved really doesnt matter. If you just burn the mpgs separately then you will almost definitely have a pause between each mpg during playback. If this doesnt bother you then just leave the mpgs separate. If you want seamless playback then join them and make chapters.
Backing up Webcam DVD's - Individual chapters
By jback in forum DVD RippingReplies: 10Last Post: 4th Dec 2010, 12:14 -
Editing individual .avi files to go into DVD.
By VenusAndMars in forum Authoring (DVD)Replies: 15Last Post: 6th Nov 2010, 03:22 -
Ripping 50 DVD chapters to individual files
By indijay in forum DVD RippingReplies: 2Last Post: 16th May 2010, 02:05 -
How to convert DVD back to individual files
By mysts in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2008, 07:19 -
DVD->DivX, chapters to individual files
By cd090580 in forum DVD RippingReplies: 2Last Post: 15th Jul 2007, 06:32
