It's me, Clement.
I'm a bit frustrated. I can't seem to figure out how to translate a wmv file to an mpeg. Using ffmpegx, I can translate the wmv video into an mpeg4 file, which I can then translate into an mpeg1 video stream.
But I cannot, for the life of me, get the audio to encode. Ffmpegx (the only program that even wants to try) can't encode the audio to any of the formats it offers. My only solution would be to use Wire Tap to capture the audio from Windows Media Player, and then chop off the beginning and the end (of dead space) using QT Pro before using MMT to encode the aiff as an mp2.
But there has to be a better way.
If anybody has solved this problem or has any suggestions, I'd be most grateful.
Many thanks,
Clement
Download Mplayer for OS X.
If Mplayer will PLAY your .wmv file with video and sound, then you can use ffmpegX and/or Mencoder to convert it to a usuable format, its just a matter of tweaking the settings.
if it will NOT play in MPlayer, you are out of luck and will have to use VPC.
Sorry.
Give it a try -- http://mplayerosx.sf.net
Movie_LeftEye.wmv + Movie_RightEye.wmv + Polarized glasses = ?
By barelief in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Nov 2011, 16:45 -
WMV to DVD or VCD Conversion
By MannyNoela in forum Video ConversionReplies: 9Last Post: 6th Feb 2008, 11:22 -
Removing Subtitles from VCDs and VCD-originated MPEG and WMV files....
By dadada_999 in forum SubtitleReplies: 1Last Post: 2nd Jan 2008, 20:49 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
