HI...I recently purchased a pinnacle PCTV. I tried to capture some videos from a VHS player but the video freezes randomly at some point during the capturing. the audio is fine but the video just stops. Sometimes about 30 minutes and sometimes at about an hour. someone told me I should switch to a 4X instead of the 8X video card that Im using but still it doesnt work. Another said I should switch to windows 2000 instead of windows Xp that Im using. An then another one said I should change the chipset coz this might be the problem or switch motherboards. What should I do?
My computer specs are:
Intel pentium 4 2.4 Ghz
Intel board D865PERL
512 MB Ram
Red Fox Ge Force4 64MB 8X
Invidia Chipset 8X![]()
I hate to tell you, but you need to take that TV Tuner back and get a WIN PVR 250 that has an MPEG-2 encoder chip. Pinnacle tuner cards are fine for watching TV, but that's about it. There's just not enouigh hardware on the card for doing quality captures.
Hi there! Yes, I hate to tell you this as well, but you have to get rid of this card....I bought a PCTV Pro about a month ago and had the same problem. Apart from the freezing problems the quality while capturing fron a VCR was horrible if compared to other cards and I guess what we all want when capturing from our all VCR tapes is the same quality, but I'm sorry to tell you you won't achieve it with this card. After a couple of weeks testing mine I had to give it back and purchased a DC10. Pretty normal card, but with a huge difference over the PCTV. Good luck!
Thanks for the help. someone suggested to me to try LEADTEK TV2000 XP DELUXE or EXPERT...are these good ?
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 02:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 06:14 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 13:41 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 17:16 -
Pinnacle PCTV USB 2 - Vista
By hellybelly in forum Capturing and VCRReplies: 0Last Post: 30th Oct 2007, 03:20
