what software do you use to burn after dvdshrink done that?
Results 1 to 9 of 9
nero express, latest version. Actually now i use an app called autoshrinkiso. Basically, it uses dvddecrypter to burn the app all in "one" step. I dont have to do anything after I click go on dvdshrink.
I used to use Stomp RNM but have used Burnatonce for a long time now and it has provided me with flawless backups using both an A05 & 106. Free from www.burnatonce.com/
There are some issues with certain burners & BAO however, the Sony's spring to mind in particular. -
Hi all.
I successfully used Nero 5.something, Prassi PrimoDVD, but I'm now exclusively using burnatonce.
As previously stated, it is a very simple and user-friendly proggy.
Strange burning issue with DVDShrink/Nero combo
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 7th May 2010, 11:00 -
Good DVD ripping software? Currently using DVDShrink.
By Hank Kinsley in forum Authoring (DVD)Replies: 9Last Post: 11th Oct 2009, 09:20 -
DvdShrink process stuck after burning to dvd .
By fibola in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2008, 11:17 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
Can DVDShrink be set to use ImgBurn for burning?
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 21st Jul 2007, 13:17
