I'm trying to compile a video montage of various movie clips for presentation to a large audience. I'm currently using DVDx to rip a bunch of DVD material I want, but I'm concerned about a few things--
Some movies are in widescreen format and some are in fullscreen. When I go to present the finished product, I don't want clips alternating between wide and full screen every two seconds. Is there any way I can crop or zoom in on the dimensions of entire video clips so there are no black margins?
My biggest problem here is that I do not know of any way to join mutiple videos of varying sizes/resolutions. I searched the how-to guides and forums for information to no avail. I want to make all of the videos into fullscreen format, and of dimensions that will easily allow me to append them together using something like Muitiquence. How can I standardize the sizes (or is it resolutions?) of all my video clips?
Also while I'm at it, what would be the best format to encode to? I'm going to be using a computer that may or may not have certain codecs, so what is my safest bet for making this work? MPEG-1? I don't think these computers have DVD codecs, so that kinda rules out MPEG-2. What about AVI?
Thanks. I'm relatively new to this, so if I'm misusing terminology or confusing the hell out of you, please question me![]()
how you will do it will depend on what video editor you use ...
as to the format .. ussually quicktime or mpeg1 is a safe bet . I would go with quicktime but also make a copy as mpeg1 as backup .. try to find out the specs of these computers -- and match your encoding to thier capibilities .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
ok; is it possible to zoom in/crop using adobe premiere?
if not, what would you recommend i use? -
zoom in/crop using adobe premiere = yes , no problem .. you can do that with about any NLE , mainconcept and sony have some good products for that also .
Problems with video, differing weird frame rates reported.
By Killer3737 in forum Video ConversionReplies: 36Last Post: 29th Apr 2012, 10:17 -
Differing volume levels on compilation video DVD
By mr_tinka in forum Newbie / General discussionsReplies: 15Last Post: 4th Sep 2009, 22:12 -
Are there different types of S video cables or is it all standard?
By PunkMaister in forum Capturing and VCRReplies: 6Last Post: 10th Jan 2009, 19:47 -
Types of Video Formats
By christopherm in forum Newbie / General discussionsReplies: 5Last Post: 18th Mar 2008, 19:48 -
All video types to standard size / format?
By fuzzyvideomunster in forum Video ConversionReplies: 2Last Post: 3rd Jul 2007, 10:50
