My HP DVD Writer dvd200e will do a great job on DVD+RW disks,but not on DVD+R disks.
I do all the usual things like defrag & make sure the writer lens and media is clean,BUT still I get the "Error on Position" write errors.
Any ideas would be appreciated.
tanx
I believe the RW and the R lasers are different, if is possible that the drive may be partially inoperable. I had a CD-R/RW drive that broke and the RW stopped working but the R worked fine.
Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
What firmware are you on?
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
My HP is running firmware 1.51,the latest posted by HP.
If you know of a later one,pls let me know.
I won't buy another HP.Got any suggestions for an Ext DVD Writer? -
If its still under warranty have it replaced
otherwise look for my guide how to flash it to Ricoh 1.64 firmware
see if it helpsYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
No they are the same laser. It takes more power to write DVD+R. Hard to say what is wrong but I agree with Tompika that retun it if it is still under warranty.I believe the RW and the R lasers are different, if is possible that the drive may be partially inoperable. I had a CD-R/RW drive that broke and the RW stopped working but the R worked fine.
RG -
Ok,so you are saying that the Ricoh Firmware is used on the HP? Are you sure it's compatible?
Thanks -
https://www.videohelp.com/forum/viewtopic.php?p=625185Originally Posted by tompikaYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Hybrid disc with both DVD-Video & DVD-ROM - is it possible to burn?
By rjamesd05 in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2009, 14:07 -
i have a 4 year old dvd burner that seams to burn a full dvd but the movie
By dr.bling in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Aug 2009, 23:20 -
How to burn RMVB files to DVD so it will play on regular DVD player
By MithrasX16 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 06:53
