Would it be ok to incode 2 vidoes at once with these system specs.
P4 2.8 with 800 fsb, 1 gig DDR 400 RAM
Give it a try and let us know how it works.
EDIT: Sorry, had a long day. Simple answer, NO. Encoding video is very CPU/Memory intensive. I usually see 90-100% CPU use. I don't see any way you can do 2 at once. You may be able to upgrade your system/Computer to achieve faster speeds. -
what are you using as an encoder? I know that your question is actually, encoding 2 videos at one time and the previous poster is right, its not. You can do it, but it'll probably take longer than if you did it as a batch job.
The batch job, would be my recommendation. If you have TMPGENC, you can set it up to do batches fairly easily. I use dvd2svcd to do batch conversions.
Hope this helps.
Can someone recommend good low-mid-price system for video-editing/capturing
By johnharlin in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2011, 08:08 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Finding a Good Capture Card For An Xbox 360 System?
By LoC Blood Red in forum Capturing and VCRReplies: 14Last Post: 8th Sep 2010, 23:06 -
First post here and first time here (surround sound system help) Plz
By Izzdan in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2010, 02:13 -
Good time to buy a TV during the year
By Ignis in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 23:18
