  1. I have some live concerts on vhs that I`m converting to VCD`s (Pal 352x288).
    Here`s the problem:
    On a music cd you can change the song by pressing Prev-Next.
    Is this possible whitout splitting the .mpg into several parts and then burn it??
    If i split the .mpg the picture freezes some seconds after each part, and I want it to play seamless + have the option to change the songs by pressing Next or Prev on the remote.
    I don`t need menu`s or fancy options like that.
    OH
    <font size=-1>[ This Message was edited by: OH on 2001-10-08 08:42:56 ]</font>
  2. Yes, you can make chapters (actually entry points) in your MPG. Hitting the << >> keys (or the number of the chapters on your remote) will take you there.
    I use TSCV (www.ttool.org) for this. It's not the most user friendly program but if you just want to add chapters it's fairly simple. There are guides at the site but also take a look at:
    http://www.personal.psu.edu/users/r/d/rdm186/
