I have a training DvD that I would like to place on 3 or 4 SVCDs I know how to break this up with dvdshrink but after that Im lost.Please Help
as foo mentioned, try dvd2svcd. You'll need an encoder like tmpgenc,cce, or procorder. download dvd2svcd from www.dvd2svcd.org
Under the guides section here, there is a poster that made a good guide for this type of conversion name cecilio. Look for his guides. To be honest, the interface for dvd2svcd is VERY user friendly and you'll probably not need a specific guide. -
I would use Eazy VCD (freeware).
It includes all the software you need for ripping and encoding (vStrip, BeSweet, DVD2AVI, TMPGEnc) but it doesn't contain burning software.
With a few simple clicks of your mouse your DVD will be ripped and a mpeg or bin/cue file (which ever you choose) will be created for burning.
I usually create a single mpeg file and then use the MPEG Tools in TMPGEnc to cut the file into 2 segments for burning.
Eazy VCD is very simple to use and, in my opinion, the results are great!
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32
