Hi guys!
I have converted an AVI to dvdr,authoring and burned with CLONEDVD.
It goes well on my stand-alone player, but sometimes it freezes.. and go on.
What can do this?
My DVD-R is a Sony and the player is not very good...
it's a problem of conversion or authoring?
THX
Try playing it on your computer. If it plays fine then your dvd player cannot read your media. Check the dvd player compatibility chart and the dvd media list to your left to see what types of media work best for your player. Sony's tend to be pretty picky about media.
Yes, any given DVD player may play dvd-r better or worse than dvd+r. You just have to test it out to see what the capabilities of your dvd player are. If it plays just as badly on your pc though, then you know that it is not necessarily the media that is the problem. In this instance either the burn is bad or your data was corrupted somehow, probably during encoding or authoring.
To block sites
By Jomapil in forum ComputerReplies: 13Last Post: 24th Apr 2012, 19:12 -
Block errors in video extracted from DVD-RAM disc
By kosdi07 in forum DVD RippingReplies: 0Last Post: 2nd Mar 2012, 15:45 -
DV pixel block help
By cg_society in forum EditingReplies: 3Last Post: 26th Oct 2011, 09:42 -
Block a file
By Jomapil in forum ComputerReplies: 2Last Post: 11th Nov 2010, 03:50 -
Does Toshiba DVD-HD Recorders block HBO,Showtime,Starz,etc from recording?
By NiteLite in forum DVD & Blu-ray RecordersReplies: 19Last Post: 22nd May 2007, 12:03
