O.K. this is a partial repost but I have gotten nowhere and i'm about to have a nervous breakdown.
Help me someone please.
I am encoding material captured via Firewire from a Sony DSR-PD150P
I am using premiere and encoding using CCE 2.67.011
the captured source plays fine an looks fine.
I am using various options to encode the video stream only and when I play back the video stream
it seems slightly fast...???
looking at the time counter on the player (Sonic CinePlayer or others), the counter is not constant it counts one secound then the next too soon.. then the next takes a proper second, it's like it's playing back.. the seconds 1,.5,1,.5,1,.5,1,.5
What is going on... the encoder is set to 25FPS i'm using PAL encosing to PAL...
WTF is going on..
any help would be appreciated
LB
try using a different encoder, like TMPGENC. if the video from that plays back fine, you'll know you have a problem with CCE.
TMPGENC is also reputedly better quality than CCE too.
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
No. Digital video is still in its infancy.This should be easy!Want my help? Ask here! (not via PM!)
Thanks for the comments!!
I'll look out for that other encoder.
Is any particular version you reccomend
Looking for an easy way to crop videos
By Sperling_96 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Oct 2011, 05:41 -
Hardsubs Easy
By kazz0817 in forum SubtitleReplies: 1Last Post: 22nd Jan 2011, 05:44 -
You Tube Question... (should be easy)
By greenstrat in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2009, 23:47 -
Is there any easy way
By kemcel in forum MediaReplies: 1Last Post: 17th Mar 2009, 09:07 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 15:43
