hi all,
im new to all this and have spent ages searchin through the forum and guides but with no success.
I have a movie in .tar format which i want to burn onto SVCD. Using UltimateZip i have extracted the .rar files, then when i have tried to extract .bin & .cue files from .rar UltimateZip comes up with the CRC error while extracting??
I'm thinking of downloading winrar to see if this works however i dont know if its worth it if UltimateZip doesn't work.
Can anyone help me please ???
Also what is the best way to convert to svcd, I have TMPGEnc & /VCDeasy.
Cheers.
Results 1 to 9 of 9
No one will help as this sounds WAY too much like you downloaded a movie and want us to help you in copyright infringement.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
when you untar it -- what do you have ? a bin and cue file ? or a mpeg file ?
no after untar im left with a rar, then i get an error when extracting the bin & cue files from the rar?
vcdeasy will burn it to disk for you with no problems.Not bothered by small problems...
Spend a night alone with a mosquito -
look the file is probabably about 800 MB right or maybe 1.6 GB. first if its 800 MB unzip it using Win RAR, and then you might get a folder that says CD1 then go to that folder and unzip the first RAR or TAR file. if its a 1.6 GB file size, then when you extract the files you will have 2 folders one saying CD1 CD2. first go to cd 1 and then extract the first rar or tar as you will get a bin cue file, and then burn the cue file using your favorite image burner. this is already most likely SVCD, or atleast vcd. then when your done delete that folder, and then do the same for CD2 folder.
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
If the tar extracted, then the download isn't corrupt, so you might just need the newest version of winrar, they changed a few things, and archives made with winrar3.2 do not extract with 3.0. It sounds like this is the problem. Either that or the person that made the tar archive, put in a corrupt rar archive.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Creating a forum
By beavereater in forum ComputerReplies: 10Last Post: 21st Apr 2009, 09:15 -
Creating Menu's
By wristar in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 19:42 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
Extract tar file in MacOS
By Simpleeme88 in forum MacReplies: 2Last Post: 30th Jun 2007, 05:14 -
Creating Movie
By Adarsh2211 in forum Video ConversionReplies: 2Last Post: 28th May 2007, 22:42
