Hi All,
I have now set up my dedicated video machine (XP Pro)
I will be ripping, encoding, transcoding and burning. I know there has been a few discussions regarding loading or not loading codecs. My question is, should I load codecs or not. I do not intend playing the files on this new machine but wondered if any of the software requires them to be able to do it's job. I will be using:
DVDDecrypter
VCDEasy
InstantCopy
DVD2AVI
VitualDub
DIVFix
IfoEdit
TMPGEnc
Instant Hidden Settings
And some light use of Ulead DVD Workshop.
Many thanks in advance for any help given.
If you want to re-encode any file from its original format to another (e.g divx to mpeg-2) then you need to be able to decode it to the same extent that a player application would. i.e, you need the right codec.
My advice w.r.t codecs is to only install a new one if you find a need for it. Do not install codec packs, get the original codec and install just that.
I value your opinion.
By circanow73 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Dec 2010, 14:22 -
VHS capture - Your Opinion?
By vidso in forum Capturing and VCRReplies: 3Last Post: 25th Jul 2010, 23:28 -
Slideshow Software Opinion?
By avguser in forum Newbie / General discussionsReplies: 10Last Post: 4th Jun 2010, 15:02 -
Your Opinion of Windows 7
By frieday in forum ComputerReplies: 31Last Post: 13th Jan 2010, 13:50 -
Laptop Opinion
By Poppa_Meth in forum ComputerReplies: 15Last Post: 7th Jun 2009, 12:16
