This is actually the Log file Nero provides, I saved it after I'd had two burns attempts fail giving me a beautiful DVD coasters. Anyone have suggestions? Just for background: I'm burning DVDs I made to another DVD+R, basically making copies using DVD Decrypter or copying the VIDEO_TS folder to the HD (I alternate, don't ask why) and then burning with Nero. I've made quite a few DVDs without problem until this error. Help please. Could it be firmware? I'm using Imation discs. THanks! -Mary
Here's the Log file.
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 4/23/99 10:22:00 PM
ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/03 3:25:04 PM
Nero version: 6.0.0.19
Recorder: <LITE-ON DVD+RW LDW-401S> Version: ES0E - HA 0 TA 1 - 6.0.0.19
Adapter driver: <ESDI_506 > HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST RW/DVD GCC-4120B>Version: 2.00 - HA 0 TA 0 - 6.0.0.19
HL-DT-ST RW/DVD GCC-4120B (Target 0, D: Autoinsert Off, DMA On, Disconnect On, SyncDataXfer Off
LITE-ON DVD+RW LDW-401S (Target 1, E: Autoinsert Off, DMA On, Disconnect On, SyncDataXfer Off
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 24117248 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 127MB (130332kB)
Free physical memory: 0MB (484kB)
Memory in use : 84 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
17.10.2003
UDF/ISO compilation
11:13:43 AM #1 Phase 112 File dlgbrnst.cpp, Line 1843
DVD-Video files reallocation started
11:13:43 AM #2 Phase 114 File dlgbrnst.cpp, Line 1843
DVD-Video files reallocation completed (no file modified)
11:13:43 AM #3 Text 0 File Isodoc.cpp, Line 5950
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
11:13:43 AM #4 Phase 111 File dlgbrnst.cpp, Line 1843
DVD-Video files sorted
11:13:43 AM #5 Text 0 File Reader.cpp, Line 118
Reader running
11:13:43 AM #6 Text 0 File Writer.cpp, Line 127
Writer LITE-ON DVD+RW LDW-401S running
11:13:43 AM #7 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
11:13:43 AM #8 ISO9660GEN -11 File geniso.cpp, Line 3882
11:13:43 AM #9 Text 0 File Burncd.cpp, Line 3198
Turn on Disc-at-once, using DVD media
11:13:43 AM #10 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 1998303 (444:04.03)
11:13:43 AM #11 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
11:13:43 AM #12 Text 0 File DlgWaitCD.cpp, Line 1949
Recorder: LITE-ON DVD+RW LDW-401S, Media type: DVD+R
11:13:43 AM #13 Text 0 File DlgWaitCD.cpp, Line 394
>>> Protocol of DlgWaitCD activities: <<<
11:13:43 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 769
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 1998304 (1998304) = #1998304/444:4.4
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1998304 blocks [LITE-ON DVD+RW LDW-401S ]
11:13:43 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [LITE-ON DVD+RW LDW-401S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4092833792, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1998304 | lead-out | 1 | 0x00 | 0x41
11:13:43 AM #16 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
11:13:44 AM #17 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
11:13:44 AM #18 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 2.4x (3,312 KB/s)
11:13:44 AM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2136
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
11:13:44 AM #20 SCSI -1066 File Cdrdrv.cpp, Line 1205
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x06466000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
11:13:44 AM #21 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 20:57,463 (1257463ms) -> OK
11:13:44 AM #22 Text 0 File DVDPlusRW.cpp, Line 564
Start write address at LBA 0
DVD high compatibility mode: Yes
11:14:16 AM #23 SCSI -1135 File Cdrdrv.cpp, Line 1413
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x01E10000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x4A 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
11:14:16 AM #24 CDR -1135 File Writer.cpp, Line 335
Write error
11:14:16 AM #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
11:14:16 AM #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
11:14:17 AM #27 Phase 127 File dlgbrnst.cpp, Line 1843
Generating DVD high compatibility borders
11:14:17 AM #28 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
11:14:17 AM #29 Phase 129 File dlgbrnst.cpp, Line 1843
Generating DVD borders completed successfully
11:14:17 AM #30 Text 0 File dlgbrnst.cpp, Line 1703
11:14:17 AM #31 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 2.4x (3,312 KB/s)
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 9/11/02 6:01:04 PM
File 'IoSubsys\DRVWPPQT.VXD': Ver=3.10.36a, size=228223 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\asapi.vxd': Ver=5, 1, 0, 2, size=14581 bytes, created 9/1/98 12:33:10 PM
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 4/23/99 10:22:00 PM
File '..\System32\Drivers\1394bus.sys': Ver=4.10.2222, size=37328 bytes, created 4/23/99 10:22:00 PM
File '..\System32\Drivers\Ohci1394.sys': Ver=4.10.2222, size=35648 bytes, created 4/23/99 10:22:00 PM
File '..\System32\Drivers\Ntmap.sys': Ver=4.10.2222, size=9360 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\Ntmaphlp.pdr': Ver=4.10.2222, size=9825 bytes, created 4/23/99 10:22:00 PM
File '..\System32\Drivers\Sbp2port.sys': Ver=4.10.2222, size=32592 bytes, created 4/23/99 10:22:00 PM
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69570 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 4/23/99 10:22:00 PM
Registry Keys:
Results 1 to 9 of 9
If possible email directly with replies.
Every now and then Nero fails for me in a similiar fashion. I cancel the burn, push the disk back and and re-burn it. 80% of the time it's fine. It looks like it started to burn and failed, didn't burn anything.
Try burning after a fresh re-boot. Every now and then something causes a burner to go out in la-la land and not zero the burn head, or not read the disk right.
Have you changed media? Check the media ID of the coasters agains known good burns: Someone else could have manufactured thoses disks and your burner doesn't like them....To Be, Or, Not To Be, That, Is The Gazorgan Plan -
jdizzy40-Originally Posted by jdizzy40
Yes, I do cdwr/dvdrom and the dvdrw of course, and I've tried the copydiscs function on so many applications and for some reason it doesn't work for me. So I just did what someone suggested, rip the dvd I made to harddisk and then reburn the video-ts folder. [I only have 20GB that's why I can't just leave the Video_ts folder(s) ;D]
Thanks!
MaryIf possible email directly with replies. -
- Actually it did burn a little, I can see evidence on the disc. But thanks! I'll do that if I catch it before it actually burns. Also, it's done this to me before as well, but never thrice in a row.Originally Posted by Gazorgan
Yep, I did it again and it did hte same thing. Get this, I didn't realize that my roomate said she used this morning and she got a major error saying that Windows was missing some dll and needed to be reinstalled. So she said refreshed the systerm (NOT format or reinstall just refresh) to return all the needed files and etc...) so it should be good, I checked the programs/appz and everything was fine, nothing needed reinstalling included (nero) so my new question is, do I need to reinstall something for the drive? Ie: drivers?
Thanks!
Hey folks,
Here's a screencappie of what the "failed burn" looks like.
Smells like Nero.
Re-Boot, uninstall Nero, re-boot, install Nero, test. May be an ASPI layer issue? Or the drive is stuck in PIO mode (can't go fast enough). Search PIO mode for directions on how to reset it for your OS.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Hey guys,
Decided to do a complete reinstall of the OS and of course Nero and all that. The roomate is not only a slob in real life but also on the PC, hehe bunch of crap on it anyway. So I sucked it up and saved everything and get this Nero is working just fine with the discs THANKS! Also, someone suggested moviefactory and it works great for authoring dvds and stuff so far so good. I use both whenever I need it. Thanks for all your help!
- MaryIf possible email directly with replies.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40
