hi, i have a bunch of dvd's backed up using dvd shrink, but now i cant burn them cause copytodvd expired on me![]()
what else can i use?
i have nero 6 ultra edition, but that doesn;t recognize the IFO file, only iso and some other one
is there any other program that can burn these? or can nero do it, just dont kow how to with nero
thx
Results 1 to 11 of 11
I am not sure about Nero 6 but with Nero 5 you have to buy an MPEG2/DVD plug-in in order to burn DVDs.
Check out Nero's website at www.nero.com to be sure.
It's been a while but I think I had to pay $29.00 for my DVD plug-in. -
Doesn't recognize the IFO file? I use nothing nut DVD Shrink and Nero 6. Works every time. What are you doing wrong?
There is a freeware tool to convert the IFO files to ISO format (dont remember which one), then you can burn with DVD Decrypter.
I think what he is trying to do is burn from image (trying to select the IFO file).
Imgtool can create the ISO or interface to Nero to Burn the DVD transparently.
I recomment this since you are not clear on how to make Nero work correctly.
I like burnatonce.com also if you do not have Nero. -
If you created the files with DVD Shrink, open up Nero 6 using Nero Express. Make sure your DVD writer is displayed in the top right. Click on DVD-Video Files. Then double click the "Red" VIDEO_TS Folder. Then browse to the folder where your movie is. Hightlight the folder and click add. Do not double click the folder, cause then you have to add the files seperately. Then click next and burn. It isn't any simplier than that.
Originally Posted by jdizzy40
i guess i just couldn't find the option before, new to nero
DVDshrink has great tutorials on how to burn with different programs,
this is the one i used http://www.dvdshrink.info/nero-video.php -
Hi all.
Thanks for the positive feedback, lukasz70, I'm glad the guide was of help to you. -
AutoShrinkISO is 100% freeware solution and you can use it at work too legally. Just need DVDShrink and DVDDecrypter.
bd rebuilder expired
By davebarnes2009 in forum Blu-ray RippingReplies: 4Last Post: 4th Aug 2009, 14:59 -
DVD2oneX2 - Expiration expired (Is there....)
By JonnyPhoenyx in forum MacReplies: 5Last Post: 8th Mar 2009, 13:17 -
TMPGEnc has expired what do I do?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 13:55 -
Burning with CopyToDVD for DLP
By ckurowsk in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2008, 00:37 -
CopytoDVD Issue
By Cybrex in forum DVD RippingReplies: 1Last Post: 30th Jun 2008, 18:14
