Hope someone can help![]()
Im trying to encode a avi to svcd using CCE but this is what it looks like:
Ive dragged and dropped my avi into CCE and hit encode and thats how
it turns out![]()
Ive read the guides btw and this isnt mentioned at all.
Any ideas whats up![]()
Thanks in advance![]()
Results 1 to 15 of 15
its prob. mentioned about 10,000 tmes now ... look for green image ..
basicly you need the right codec (somehow i just bet this is a xvid)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You don't have the right Codec. That or CCE is using the wrong codec to decode ( search 4cc ).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
as mentioned in the posts above, you do not have the correct codec. In the tools section to the right, download:
1. divx codec pack
2. xvid codec
3. dvd2svcd
dvd2svcd is an awesome automation tool which takes the human guesswork out of conversion. It will also prevent your next post regarding audio/video sync issues (which xvid's and divx films usually have). -
Wow
you were ALL correct, you really know what your talking
about lol!
All i did was tweek the Four cc changer as Gazorgan mentioned.
Second thing, macleod your 100% spot on about my next question being about out of sync audio. I encoded it a little and then checked it back and yep
audio was out and the people looked stretched.
Re:dvd2svcd, can it be used for avi's because the name is misleading don't
ya think.
Thanks for all the help guys, you do a great job
Respect. -
Yes, it will do AVI's, you just change the source from DVD (there's a button).
Dowloaded DivX and XviD have VBR (Variable bitrate audio) that CCE and TMPG don't like. There are numerous guides and threads on the subject. It's not hard to deal with, it jsut requires a few extra steps. DVD's are actually easier to work with than unkown AVI's.
Get yourself a copy of gspot for identifying what you have, and if you can render (view/hear) it.
Get the newest copy of VDUB , since it's indespensible for dealing with/editing AVI's and their audio.
You will also want BeSweet and the GUI, for doing all things audio (conversion wise). ac3fix is useful also, when you get a AC3/AC5.1 audio track that needs converting.
DVD2SVCD isvery usefull, and if you sit there and watch the first 20 minutes, it will help you a LOT in the methodology of conversion.
People stretch is Aspect Ratio issue. Don't confuse it with resolution issue. Computer pixels are square and TV pixles are rectangles. That explains the fat/thin people. Excellant informative articles on this site for it, with examples.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
as garzogan mentioned, dvd2svcd will do avi's VERY nicely (and the name is misleading). before I found dvdshrink, 90% of my conversions used dvd2svcd. If memory serves, I have never had a audio video sync issue with an avi/divx/xvid when I used dvd2svcd. All you will need to do is select avi as your input source and then let it do its thing. If you click advanced in the misc tab, you can then go to the frameserver tab( dont know why its there) and you can change the resolution to vcd,svcd,cvd, or dvd.
Cecilio has some guides about this and garzogan is right about using dvd2svcd to give you a heads up on the methodology on conversions. It gets mindboggling thinking about all of the disparate applications you have to do to do a conversion, but dvd2svcd really pulls it all together and gets you to think about the process logically.
If you have installed all of the correct codecs, do it with dvd2svcd and see how it looks when its done. I am willing to bet that you'll be in sync. -
Im back again, my apoligies
Ive d/loaded dvd2svcd but im grtting these errors:
Unexpected end of archive - when i click the zip.
I cancel that to reveal the dvd2svcd.exe inside, when i attempt to open it i then get this:
! C:\Documents and Settings\Desktop\dvd2svcd.zip: Either multipart or corrupt ZIP archive
! Cannot execute "C:\DOCUME~1\LOCALS~1\Temp\Rar$EX00.485\D2S121B3.e xe"
Ive d/lloaded it twice and tried extracting all files but same thing happens.
How do i get this too work
Thanks for your time - again
try downloading it from a different mirror , don't use a download manager either ..
you need to have a registered version of cce as demo has no ecl support . or use cce 2.5 or one of the ecl support programs for cce ..
you should use a registered copy of CCE no mater what you do anyway ."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
dvd2avcd doesnt use CCE to encode the audio , so if it crashes on the audio portion -- its some other problem. what does your log file say (exactly)
Hmmm.
Think you can ignore my last post now
I just tried encoding again and it's done it without probs
Very happy, i think i can safely let this thread go now
Cheers guys.
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
GOP questions in Cinema Craft Basic v2.7
By schrakapouet in forum Video ConversionReplies: 3Last Post: 22nd Aug 2008, 13:54 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
