im using d latest ver. of tmpgenc rite now. n everytym i try to encode a file, no matter wat file it is, there will always be a pop-up box saying tt d file is unsupported or corrupted. wat's wrong? this never happened b4... is there a way to solve my problem?
Results 1 to 18 of 18
it still wont work! i've set d DirectShow Multimedia File Reader and increased its priority. n i've d/l divx. but d same problem still occurs. n yes, all d videos work perfectly fine on windows media player etc.
Checked 4 d bad frames?
"Art is making something out of nothing and selling it." - Frank Zappa -
This fixed my problem. See #1.
https://www.videohelp.com/sefy/?id=help4.htmlDon't squat with yer spurs on. -
my files are not dvds. their mostly in asf n wmv n avi format. i had no problem encoding all these files in the past. now, there's always this error.
oh...i've fixed my problem. i set all d plug in's prioty higher. thnx for those hu helped anyway
damn it! now i can insert a video but no audio. d audio column is empty no matter wat file i put. n i cant insert any audio. d same pop-up box wud appear. help?
Try using an AviSynth AVS script to input your file into TMPGEnc or load the file into VirtualDubMod then frameserve to TMPGEnc.Originally Posted by modzon
Sometimes doing it either of those two ways will resolve problems VS loading the file DIRECTLY into TMPGEnc.
i've figured tt once d files r avi, only then can they can be encoded wif my idiotic tmpgenc. anyway, i converted d files in asftools. now d only problem is d file is WAY WAY WAY too big. is there any program to compress d file? i cant do it wif virtualdub. some kinda error came out.
First, lose the mall talk. Next, ask detailed questions with full sentences. I have a hard time following you when you make up words.Originally Posted by modzonWant my help? Ask here! (not via PM!)
im sorry if i offended u. cos im really stressed out. y cant it work lyk d past?! n wat do u mean by full sentences? arent my sentences full enuff?Originally Posted by lordsmurf
id try 2 hlp but u r mkng no ¢s.
Now that I got that out of my system,
Try setting all of the environmental priorities back to default (right click, default). Next demux the audio from the video using VirtualDub. Now tackle both files independently. Want to know how? Try the Guides section. -
i cant... u see, d files tt i cannot encode are asf and wmv files. d avi files are alright.tt's y im trying to convert d files to avi. but after conversion, a files become really large. tt's y i need to compress them. but i need a program to do it(other than virtualdub). is there any other program tt allows me to compress files? n btw, u know tt asf n wmv files cant be opened in virtualdub. so i cant do wat ur trying to tell me to do.
Modzon - I think people might be a little more willing to help if you took their advice/request seriously and stopped typing like you are texting on a cell/mobile phone.
A few people have asked, but you continue. It frustrates and aggravates people.
If they're willing to try and help you, you should try bending that little bit. :c)
It might be acceptable for texting - it isn't liked or appreciated here.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
ok, ok, im sorry if im irritating u guys. but i just need to know what programmes allow me to compress files other than virtualdub. is there another programme?
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 13:01 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 15:41 -
VOB2MPG 0 Vob Sets Problem - wont work
By meno in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Oct 2007, 22:36 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 20:04
Good God ........Did I just wake up in Grade 2?!
