  1. Hi Guys,
    I have a 99.24 mins divx avi file which i opened with VirtualDub to CUT to fit into a CD. But when I opened the file this following error msg appeared. Can anyone please tell me, how to solve this matter with VIRTUALDUB, because I tried to cut it by other editing tools but audio and video missmatching after cutting.
    ERROR MSG:
    "VirtualDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 20894 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate: 127.8 +-13.1 kbps)"
    Please tell me the steps how to solve this. Thanks
    Madkazaauser
  2. Member holistic's Avatar
    May 2001
    here & there
    Do as it says......... save *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder
    Do a [search] there is a question a day on this issue.
    FYI With an name like madkazaauser and a postlike this you may not earn to many "FREINDS"
  3. Or use vdub-mp3-freeze instead of vannilla vdub.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  4. Thanks Guys for your help.
    I am very sorry about the name, I just couldn't find a good name when I registered. I was an hurry to have a suggestion on this matter. Btw, I'll change it. No offence.
    But as you said, "post like this", can you please clarify how should I post? I don't use Fourms too often, so I donno the rule. Thanks
    Take care
    MKuser
  5. Originally Posted by madkazaauser
    Take care
    MKuser
    If you take a look at the forum rules it states No Warez discussed. This means NO talk of pirated movies. Your user name and the fact that you have a 99 min DivX file indicates to people that you use Kazaa to obtain what is most likely a pirate movie. I'm not saying it is but it could well be.
    At least you didn't start with "I've d/l the new matrix but cant convert it to VCD . . "
    Try using Vdub MP3 freeze instead of normal vdub to get rid of this message.
  6. THanks a lot
    I understood what you said, I am very sorry and I'll not use this nick to post messege again.
    "NoNewNameTakenYet"
