I was looking for a basic VCR/VHS to DVD tool and found this one:
http://www.kworldcomputer.com/kworldcomputer/www.nsf/h/dvdmaker
I inserted the CD that came with it and plugged in the device. Installed the drivers and rebooted... Now whenever the program 'USB 2800 Video' is enabled under my Device Manager - my computer will sometimes freeze up and get the blue screen fatal exception error.
I have WinXP SP1, 2.4GHz P4, 512MB memory....
But when I load the capture software that came with the device - everything works... as long as the software is running... When I'm finished capturing video, I have to disable the 'USB 2800 Video' under my Device Manager right away or the computer will lock up again.... Any ideas???????????????
did you find a solution to the problem? i may have the same prob when i get mine in the next few days.
Sound wont work on KWORLD DVD Maker USB 2.0
By BiggerJim in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 07:06 -
kworld dvd maker 2 help
By itsicon in forum Capturing and VCRReplies: 39Last Post: 18th Dec 2010, 11:21 -
Kworld Expert dvd Maker - S-Video no picture
By johnstede in forum Capturing and VCRReplies: 3Last Post: 9th Aug 2009, 08:54 -
Problem with kworld dvd maker 2800D usb - Compression artefacts?
By jhowee in forum Capturing and VCRReplies: 5Last Post: 10th Feb 2008, 06:48 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59
