I have digital camera that could shot a movie with 15 frame/sec.
Is there any tools to increase the frame rate? using interpolation maybe or other alghorithm ...
If you want to know if there is a free tool, well yes. Avisynth has a few options:
ConvertFPS [yuy2]
ConvertFPS(clip clip, float new_rate [,int zone, int vbi])
ConvertFPS() is a video filter for AviSynth. It is available as of AviSynth 1.0b7.
The filter attempts to convert the frame rate of clip to new_rate without dropping or inserting frames, providing a smooth conversion with results similar to those of standalone converter boxes. The output will have (almost) the same duration as clip, but the number of frames will change proportional to the ratio of target and source frame rates.
The filter has two operating modes. If the optional argument zone is not present, it will blend adjacent video frames, weighted by a blend factor proportional to the frames' relative timing ("Blend Mode"). If zone is present, it will switch from one video frame to the next ("Switch Mode") whenever a new source frame begins, that is, usually somewhere in the middle of a target frame. Switch Mode assumes that the output will be shown on a TV where each frame is scanned from top to bottom. The parameter zone specifies the height of the transition region in which the current frame will be blended into the next.
Blend Mode will cause visible, although slight, blurring of motion. This is a typical artifact of frame rate conversion and can be seen on commercial video tapes and TV programs as well. When working with interlaced video, it is important to let the filter operate on individual fields, not on the interlaced frames. (See Examples below.)
Switch Mode is an attempt to avoid motion blurring, but comes at the expense of slight flicker and motion artifacts. Horizontal and vertical pans may show a slight wobble. Still frames from this conversion show "broken" or "bent" vertical lines in moving scenes. Scene transitions may occur in the middle of a frame. Nevertheless, the results do look less blurry than in "Blend Mode".
Neither mode is perfect. Which one to choose depends on personal preference and on the footage to be converted. Switch Mode is probably only suitable if the output will be shown on a TV, not on a computer screen.
Frame rate conversion is inherently difficult. This filter implements two common methods used by commercial Prosumer-level converter systems. The results are typically quite good. More sophisticated systems employ motion interpolation algorithms, which are difficult to get right, but, if done right, do yield superior results.
Footage converted with this filter should not be converted again. Blurriness builds up quickly in subsequent generations.I mean it in the nicest way.
Remain Bit rate or increase when convert to dvd?
By sychern in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 18:26 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
increase the frame width with virtualdub?
By sharmine in forum Video ConversionReplies: 3Last Post: 17th Sep 2007, 17:17 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15 -
Increase audio velocity in SONY VEGAS 7.0 and freeze a frame?
By qazwsx16 in forum EditingReplies: 9Last Post: 30th May 2007, 20:35
