Standard DV AVI files captured to NTFS partition with ULEAD CAPTURE 6.0
that reveal a property of "SONY DV CODEC 720x480 w/48K 16bit audio"
are showing up on the timeline in PREMIER PRO on another machine
to only have 5 MINUTES of content..Its as If the files are bad?
The file can be played in the Media Player (6.4) and is fine out to 46 minutes and another one clocks in at 30 minutes, but both show a
freeze frame and no audio after the 5minute point
What gives..
Other formats - 30 min MPG alread edited, and another AVI file that was 10 min showed up fine.....
I think the files are good cause VEGAS accepts them on the same machine I've moved them to without issues..
Do you have to capture with premiere now that 7.0 is out..I never haddda capture in premiere to use it before?
Results 1 to 1 of 1
Premiere Pro don't read my .vob files in OS X Lion
By Atoon in forum MacReplies: 10Last Post: 6th Mar 2012, 00:09 -
Is there a way to batch convert files in PREMIERE PRO
By mudh in forum EditingReplies: 13Last Post: 12th Oct 2011, 11:23 -
Combining VOB & AC3 to DV AVI Files for Editing in Premiere Pro CS4
By foochuck in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 14:08 -
Adobe Premiere Pro 1.5 files comptible with CS3/CS4?
By vid83 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Feb 2009, 14:15 -
Cant import AVI files into Adobe Premiere Pro 1.5 (again)
By Undead Sega in forum EditingReplies: 1Last Post: 13th Oct 2007, 20:35
