What is camera passthrough meant for then?Originally Posted by zoobie
Results 181 to 189 of 189
I really don't know. It's just what I've researched here and other places. You're probably better off finding another way.
As for passthroughs - well one of the reasons I was considering the ADV55 was because using a DV camcorder wouldn't work for me since I have a large selection of both PAL and NTSC tapes I would want to convert. My current camcorder is a NTSC Hi8 which works fine (even after 12 years!). I now live in PAL country and I thought about getting a NTSC D8 camcorder so I could play my existing tapes and also do passthrough of my extensive NTSC selection. But there is no solution for my PAL tapes. The ADV55 would do that.
But as I noted before in an earlier post, experiences with a WinTV PCI card and a reasonably fast PC with a fast HD seems to be promising. Of course if the tapes are really bad not having a TBC might be an issue but most of my tapes are in reasonable shape (most recordings are first generation off TV)
Larry -
Camera Pass thru works fine. However you may need to add an image stabilizer in between to get the best results. The point here is you can get a DV camcorder for as little as $200 now with pass thru and have the best of both worlds. I am not overly concerned about mpg2 capturing since this is a terrible format to edit videos with and bottom line when I am done editing I can then author and render it which usually gives better results. However, if I do want to encode directly to mpg2 I can do this with my AV Pyro in real time as well and yield good results.
Lastly, I did not realize that this post was drug up from the archives. I have an original post back in 2003 hehe with the same opinion.
Originally Posted by dun4cheap
zoobie said
I'm always thinking high-end results but I basically agree. It's probably fine for low-end home editing results.
Maybe a new thread should be started about professional hardware solutions. -
Hey Guys,
Very informative and helpful.
I make videos for personal use and friends with Premiere Pro and wanted to be able to look into converting old analog footage into usable digital format. I researched several converters and considering my limited budget went with the ADVC 110 from Canopus.
Please tell me it will get the job done in terms of simply running a VHS VCR straight into my PC. Most people I spoke with said it would get the job done fine.
regards -
It should do this just fine. Just remember the quality will not be anybetter than the source, so don't expect miracles. You can run it through filters.
Thanks man.
I am not expecting anything too great, just want the footage in digital format as a means of doing something with it.
cheers
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 14:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 17:26 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
