ti need an editing programme.i want to cut and joing avi files . if there is a good programme that could help please tell me about it and where i can get it. and as always the free and easy are better![]()
plz help me
I think anything available was already covered in your other thread here: https://www.videohelp.com/forum/viewtopic.php?t=182728&highlight=
Have you peeked into the Tools database yet? Look at Basic Editors & Advance Editors. Lists of programs, prices, user comments and Guides to use them. Even links right to the download itself. Just about anything anyone could mention in this thread can be found there.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
forget about helix could u help me with the editing programme plz
i took a look at what u mentioned but could find what i need . if there is something i didn't see in the site . could u give me the link to it plz.
and sorry for posting the same thing twic -
There are loads of things :c*
I, personally, use a combination of a lot of programs. Lots of people do. But most of mine are not free.
You want free? Get Virtualdub, mentioned many times on this site. It was right on the list I suggested you look at.
So is tmpgenc. Another one mentioned probably hundreds of times a day :c) in posts and on that same list.
Friendly advice - you need to be prepared to read up about things a bit if you want to be able to do all this and do it well.
Good luck. Have funThere's no place like 127.0.0.1
i already have virtual dub but i don't know how to cut and join with it. by the way want to join diffrent files to each other.
is there a thread or a link in the site that helps with that.
or can u tell me how or where i can find the way to teach me how to do it
thanks for the programmes u gave me
Go to the link you've just created to virtualdub. Under it are listed various Guides on how to do many things with it.
You can easily find the exact one that tells you exactly what you need to know.
I pointed it out in my first post to you. :c*
Look at Basic Editors & Advance Editors. Lists of programs, prices, user comments and Guides to use them.There's no place like 127.0.0.1
i went to that page but i didn't notice the link till u told me about it.
thanks fpr the hel i'll try to do it now -
Good :c) Good luck.
Building a PC for Video Editing/Encoding - Need Advice plz!
By MaTTuP in forum ComputerReplies: 9Last Post: 6th Nov 2010, 10:37 -
Programme picking help
By zinc in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2009, 07:09 -
How to check what authoring programme was used?
By grzegorz in forum Authoring (DVD)Replies: 4Last Post: 4th Dec 2008, 01:26 -
converter programme
By VaGaBoNd in forum Video ConversionReplies: 2Last Post: 27th Feb 2008, 04:33 -
good editing programme
By leegutcher in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2007, 07:28
