Can a dvd compliant Pal clip and an ntsc clip be authored onto the same dvd disc?
Well you can't have PAL and NTSC on the same volume. So you'd have to use a double sided cdr (dvd-10.) I'm not sure whether the second layer on a DVD-9 would be considered a second volume, but I don't think so. So basically as far as you are concerned, unless you are using double sided media, the answer is no. But that is just what the standard says. Lots of software will let you do it and I doubt there are very many players out there that wouldn't be able to play them properly assuming the player supports both PAL and NTSC decoding.
Every time I make a stupid mistake, I write it down in my video notebook. This was one of them. Even if the authoring program allows it, the players won't (not even computer software players).
Yes it can.
I have used DVD Shrink version 3 beta 5, using re-author mode to make a disc with a PAL movie and a NTSC movie on it.
dlb. -
Yes you can (at least it works here in PALsvile)
https://www.videohelp.com/forum/viewtopic.php?t=180649&highlight=pal+ntsc -
Just for clarification, yes you can do it but its not going to be compliant. Whether it plays correctly or at all will depend entirely on your equipment.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
