Every time I try to make a VCD my stand alone Daewoo dvd player wont play it. I am using nero 5 and TMPGE. I have managed to make one vcd and get it to play on my dvd player, but I dont know why that worked and the others dont. The file I used to make the sucessful vcd was already in mpeg format and all I had to do was make a VCD in Nero.
My television is a PAL format.
I have used TMPGE to convert AVI files into MPEG1 or MPEG2 files, changed the frame rate between 29 and 25, what am I doing wrong, nothing seems to work and my wife is running out of uses for my coasters.
1) Check you are using the right templates in tmpge
You shouldn't be able to change the things that stop it from working, but check your resolution is 352x288, mpg1 and 25fps.
2) Use CDRW to test burn onto, that way you don't keep wasting CDR's. -
Yes thanks very much for the good advice. I used the TMPGE template and it worked perfectly.
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 23:56 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 16:15
