I have a Panasonic DMR-HS2 and want to be able to make copies of my DVD collection and record from directv.
I have tried to find the best way but have come across much confusion.
Hopefully some talented people can all post solutions here once and for all.
1. Are there any hacks avail. ?
2. Does a video stabilizer work ? What is the best one to use ?
3. Any other ways to do this ?
Results 1 to 14 of 14
1. No
For 2 & 3, Check here...
https://www.videohelp.com/forum/viewtopic.php?t=182046&highlight=macrovision
and here...
https://www.videohelp.com/forum/viewtopic.php?t=175615&highlight=macrovision
You will need something that works with BOTH Macrovision and CGMS
Tearren -
I would like to add the best method to back up DVD's is with a PC DVD burner.
You get to keep the various audio tracks including 5.1 surround sound, DVD menu's, and extra features.
So you can spend $80 to $200 on a device or buy a PC DVD burner for around $150. Personally I'd go with the DVD burner.
It's your call though.
"record from directv" - ????
Tearren -
The product from FacetVideo seems to be for analog video to DVD, not DVD to DVD as in digital to digital, or is there something I missed??
The first FAQ only mentions VCR to DVD. It also says composite and Y/C ins & outs. Am I to assume that the transport form for the signal is analog within the computer from player to burner?? -
Originally Posted by videobruce
How can it work witrh IDE cables within a computer when the device only has composite and Y/C connections????
You should read little bit more on this site ....Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
That's what I have been doing, but you can't find everything.
OK, I still don't see what a external box with composite and Y/C connectors fits in other than viewing it on a monitor or copying to to a VCR?
If the DVD has copy protection how can it be copied within the computer and why is this external box needed? -
Ripping programs like DVD Decrypter will "rip" a retail DVD to your HD and remove any copy protection as it rips. Those files can be burned to DVD-R for playback in DVD standalone.
1. From DVD Player to DVD Recorder. For this you need BOX that removes protection. You loose quality and 5.1 sound + extras and so on.
2. With PC from DVD-ROM to HD and from HD to DVD Burner (Writer). All you need is just software. No box. If you know how, you don't loose anything.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
I have bought a external dvd burner for my computer.
From what I understand right now there is no way to make a decent copy with the Panasonic DMR-HS2.
You end up losing sound quality etc.
I hate that I wasted so much money on the Panasonic.
Maybe something will come along in the future and make this mach. worth the price.
The only way I can see it being useful is if someone can find a macrovision hack.
Anyway, for now I will be burning dvd's with my computer. -
I don't understand why you think you "wasted" money on the DMR-HS2. I think this is the coolest device since the orignal consumer vcr came out in the '70s (yes, I'm that old.)
I have both a DVD burner for computer, and an HS2, and I love them both.
If you bought the HS2 just to copy DVD's, then yes I guess that was a waste of money. -
Originally Posted by elkfirPinnacle Studio 8 and DV home video editing (ver.9 already home)
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 14:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 12:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 02:12
