I recently bought an Epson Photo 900 printer for printing on my Ritek Printable DVD-R's, but was interested to know if anyone has tried these small "hub labels" on CD's or DVD's?
The main reason I'm asking is because I may have a large batch of DVD-R's to print for an upcoming job, and don't want to use all the ink from my Epson 900. It would also be cool to use the 9.4GB DVD-R media and the hub labels.
Just wondering if anyone has any experience with them. Here's a link to a place that sells them:
http://www.labelgear.com/LG/Product.asp?ProdCode=13606
have beeen using them for about 4 mos. now, work great, if you use the clear ones, just give them extra time to dry,
Bloo -
they are great and damn cheap, 3000 for $30. Not bad. they are what libraries use for archival purposes etc... :
http://www.gaylordmart.com/adblock.asp?abid=88&sid=C2918750EBD9444B93531129D4F1D5&sear...or=CD%20labels
or
http://www.gaylordmart.com/search.asp?sid=C2918750EBD9444B93531129D4F1D5 -
Thanks for the responses.
I guess my main concern is playback compatibility. I have experienced this issues with the full-size DVD labels and no longer use them. Have you guys had any playback issues with these hub labels? I'm only planning on using them on DVD-R (video) disks, so set-top compatibility is my main concern. -
they don't effect playback at all, all the DVD's(and CDs) I get from the library have them on- no problems.
Removing Hub Labels
By rvman in forum MediaReplies: 10Last Post: 3rd Jul 2008, 12:06 -
Visual Hub interlaced video to DVD
By chrjohns in forum MacReplies: 1Last Post: 29th Jun 2008, 21:42 -
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 05:31 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 08:06 -
DVD case question... Hub sensitivity
By richapple in forum MediaReplies: 6Last Post: 27th Jan 2008, 21:12
