macguyver- I think I had the same problem as you-
When you ripped the DVD, did you extract the m2v files from the vob files seperately? Or did you extract it as one giant file? (I dont think that is possible)
I found that I had to extract the sound in the same way i extracted the m2v files (so if you have 4 video files, you should extract the sound so you have 4 sound files)
Go into final cut pro and create a seperate sequence for each part of the movie. The sound and video should match up with a little bit of speed editing on the part of the sound.
You may lose a bit of continuity, but thats the best way I know of.
I hope this is a help
JB
	Easiest way to combine a ripped video (mov) and audio (aiff) file is to use Quicktime Pro.
 Open both files in Quicktime Pro. Activate the video file window and select all. Then activate the audio file window and "Add scaled".
 Check if sound and video is in sycnh. If not you can fiddle with offsets and scaling with QTMutator.
 I tried FinalCutPro which was a pain in the ass to use but the above method worked flawlessly with Planet of the apes.
  downsizing a mov on macBy devdev in forum MacReplies: 1Last Post: 18th Apr 2012, 11:13
  Converting/Combining MOV's and other formats to produce a Power PointBy rocks911 in forum Video ConversionReplies: 4Last Post: 20th Mar 2012, 10:48
  AC3 -> AIFF, and AOB -> AIFF for Jaguar 10.5.6?By DeadSirius in forum MacReplies: 4Last Post: 29th Dec 2008, 15:54
  Looking for a Mac app to convert .vob to .mov...By Abiyad in forum MacReplies: 2Last Post: 22nd May 2008, 17:04
  How do I convert .rm to avi/mp4/mov with a mac?By VidHunter in forum MacReplies: 15Last Post: 17th Dec 2007, 05:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
