Hi everybody.
I'm trying to convert a pal dvd to an ntsc dvd.
So i convert the video in the good format and for converting ac3 tracks, i'm using Besweet...
But i don't understand why, when i listen the new ac3 track that besweet has created, i can heard somes "crack" during the playback that they don't exist in the original files of courses....
I made several tests and if i convert the ac3 in 29.970, they're is no problem!!
Here's my command line:
"BeSweet.exe" -core( -input "F:\input.ac3" -output "F:\output.ac3" -logfilea "C:\BeSweet.log" ) -azid( -c light -L -3db --maximize ) -ota( -r 25000 23976 ) -ac3enc( -b 448 -6ch )
The original ac3 have a bitrate of 448.
I don't know what to do![]()
Someone have an idea please?
thx!
Download and use the newest BETA versions of BeSweet and the BeSweetGUI (if you use that).Originally Posted by atlas
Also you are doing 5.1 channel audio so you are actually better off using AC3Machine than the BeSweetGUI
For instance ... for 5.1 to 5.1 you don't want to do those commands you used in AZID so using AC3Machine as your front end to BeSweet is probably the best thing to do.
Thx for your reply
So i have try with ac3 machine but it's the same result
Here's the commande line create by ac3 machine:
"C:\BeSweet.exe" -core( -input "F:\input.ac3" -output "F:\Output.ac3" -logfilea C:\BeSweet.log ) -ota( -d 0 -r 25000 23976 ) -ac3enc( -b 448 ) -profile( The AC3Machine v0.4 )
I don'T know what to try
Did you downloaded and use the newest BETA version of BeSweet?Originally Posted by atlas
The so-called STABLE version has a problem with the frame rate change.
- John "FulciLives" Coleman
P.S.
In your first post you were doing 6 channel and in this post there is no 6 channel "flag" in the command line so which is it?"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Ho yes man!
Thx a lottttttttt
I try with the beta version and it's work GREAT now
So it was a bug in the actual version of Beesweet
Bye!!!! -
I am glad you got it to work afterall but ...Originally Posted by atlas
If you read my first post I did indicate that you should use the newest BETA version of BeSweet.
This video stuff can get complicated and confusing sometimes.
All I am saying is make sure you pay attention in the future
AC3 audio: 25 to 23.976 fps
By leghorn in forum AudioReplies: 7Last Post: 14th Mar 2012, 02:36 -
23.976 to 29.97 weird FPS problem
By michcio in forum SubtitleReplies: 10Last Post: 11th Jan 2011, 05:58 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Difference between 23.976 fps and 23.98 fps ???
By wasimismail in forum Authoring (VCD/SVCD)Replies: 5Last Post: 27th May 2008, 01:42
