Finally gonna bite the bullet and get a DVDRW drive. As always on a tight budget, but need dual format (making family movies for multiple family members with multiple DVD players...)
I've found two dual burners for ~120 each, with black bezels so they match my Dell (a must)
One is the Optorite DD0201 ( Formally DD0203 ), which comes with some software, 8MB cache... or the NEC 1300A bulk drive (no software) with 2MB cache. I already have Nero 5.5.10.. which says it supports the NEC drive, and I'm using Pinnacle Studio 8 which some have used with the NEC drive- so the no software is not a deal breaker.
I just wanted to see if there was any reason to choose one or another. From looking around on this site already it seems the Optorite may be a little more picky with the media.
Also, there's a MicroAdvantage dual drive at office max this week for $99 after some coupons and rebates- any experience with this drive?
Long post, I know, but thanks for any help.
Results 1 to 12 of 12
I have the Optorite DD0203 and have had no problems at all with it. My discs can be read by all 3 of my standalone dvd players and I haven't found any media that hasn't worked perfectly yet. I have used DVD+R and DVD-R, I haven't used any RW yet.
I'm still cranking out all sorts of discs with my Optorites and nothing negative to report. Mine's a little picky with DVD media, but no bother.
Another Optorite user here,all I have used is +R and +RW,overall very happy with it.
NEC 1300 User. Drive is a great workhorse - never gives me coasters. I use Princo, Verbatim and Taiyo Yuden media. I'm using the hacked firmware patch.
I have optorite dd0203 too, Just bought it yesterday, have burn some cd-r's and one dvd+r without problem. I did buy the NEC 1300A but was DOA, had to return it.
thanks for the feedback so far. I guess I was kinda leaning to the NEC just because it's a brand I know (My CDRW is NEC) but the optorite seems to have decent reviews and it comes with some software. I currently don't have a DVDROM on my PC, so I don't have DVD playback software.
if the optorite isn't supported by Studio 8, studio has an option to "create disc content but don't burn" and write the files to a disk. could I then place those files on a DVD using Nero?
PS- what version of Nero comes with the optorite drive? if it's Nero 6 that may do it for me, I've been wanting to upgrade from 5.5.xxx. is it a fully functional version or a limited OEM. -
If you look hard enough you will find people with 'issues’ on both the mentioned drives,
I own the optorite and have no prob with it – and I don’t use any of the software that came with it.
Using VideoStudio 7, Nero, TMPGEnc DVD Author and dvdshrink all with no probs (always burning with nero)
Plus optorite had HD-BURN -
Found it. Its the Sanyo HD-Burn chipset. I believe that Plextor is using the same CS for their 8X drive.
RG -
my DD0203 works great n the HDBurn is really neat. burnt 1.42GB on a 700MB CD-R. little fussy with cd-r media for hdburn. Fuji works great for hdburn.
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 21:39 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 13:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
