I wasn't really sure where to make this post, so I put it here.
I have 4 MPEG movies that I incoded using TMPGnc with a bitrate of 2000 kbps. I took this 4 movies and made them into dvd files to burn to dvd using TMPGnc DVD Author. This gives me a dvd to burn of around 8 gigs. Given the incoded bitrate of 2000 and if i where to use DVD Shrink to compress the DVD files down enouh to burn to 4.7 DVD disc, do you think the movies will be of good quality ?
Only you can be the judge of that. Try it and see. Remember to use a rw disc, just incase it is crap.
dlb. -
......do you think the movies will be of good quality ?
Compared to what? You be the judge. Personally i think they will look like crap.
Think about it .....
......bitrate of 2000 kbps......gives me a dvd to burn of around 8 gigs...
DVD = 4.38 you have 8 @ 2000 therefore 4.38Gb will be an averaged bitrate of 1200ish.
Well I tried it, and lets just say I ended up with a SVCD. It didn't always look like poo, but there where times in the movies when it would block up and stuff.
How to do a dvd shrink containing only the movie without menu's etc
By vain in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2009, 09:57 -
how to shrink a movie to fit a dvd 5?
By just in forum Newbie / General discussionsReplies: 2Last Post: 30th Oct 2008, 00:58 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
Shrink DVD movie
By Bookmaster in forum EditingReplies: 3Last Post: 24th Dec 2007, 07:41 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
